accessDoor.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object accessDoor can be read and written using a single IOTag.
accessDoor-<objectAddress>.relinquishDefault |
<type> = 30 |
<property> = 104 |
An integer representing one of the options of enumeration <BACnetDoorValue>.
