accessDoor.reliability |
Indicates weather the presentValue or the operation of the physical input in question is 'reliable' as far as the BACnet Device or operator can determine, and, if not, why.
Property reliability of object accessDoor can be read and written using a single IOTag.
accessDoor-<objectAddress>.reliability |
<type> = 30 |
<property> = 103 |
An integer representing one of the options of enumeration <BACnetReliability>.
