accessDoor.doorUnlockDelayTime |
Indicates the duration of time, in tenths of seconds, which the physical door lock will delay unlocking when the Present_Value changes to a value of PULSE_UNLOCK or EXTENDED_PULSE_UNLOCK.
Property doorUnlockDelayTime of object accessDoor can be read and written using a single IOTag.
accessDoor-<objectAddress>.doorUnlockDelayTime |
<type> = 30 |
<property> = 232 |
A 32-bit unsigned integer.
