accessDoor.doorPulseTime |
Indicates the maximum duration of time, in tenths of seconds, for which the door will be unlocked when the Present_Value has a value of PULSE_UNLOCK, after which time the Present_Value shall be automatically relinquished at the priority that established the PULSE_UNLOCK command.
Property doorPulseTime of object accessDoor can be read and written using a single IOTag.
accessDoor-<objectAddress>.doorPulseTime |
<type> = 30 |
<property> = 230 |
A 32-bit unsigned integer.
