accessDoor.doorExtendedPulseTime |
Indicates the maximum amount of time, in tenths of seconds, which the door will be unlocked when the Present_Value has a value of EXTENDED_PULSE_UNLOCK, after which time the Present_Value shall be automatically relinquished at the priority that established the EXTENDED_PULSE_UNLOCK command.
Property doorExtendedPulseTime of object accessDoor can be read and written using a single IOTag.
accessDoor-<objectAddress>.doorExtendedPulseTime |
<type> = 30 |
<property> = 227 |
A 32-bit unsigned integer.
