accessCredential.traceFlag |
Specifies whether the credential is being traced. When a traced credential is used at an access point, the Access_Event property of the corresponding Access Point object shall be set to TRACE.
Property traceFlag of object accessCredential can be read and written using a single IOTag.
accessCredential-<objectAddress>.traceFlag |
<type> = 32 |
<property> = 308 |
