accessCredential.threatAuthority |
Specifies the maximum threat level for which this credential is valid. If this value is less than the Threat_Level property of the Access Point object where the access credential is used, access is denied. If this property is not present, the threat authority of this credential is assumed to be zero.
Property threatAuthority of object accessCredential can be read and written using a single IOTag.
accessCredential-<objectAddress>.threatAuthority |
<type> = 32 |
<property> = 306 |
A 32-bit unsigned integer.
