accessCredential.lastAccessEvent |
Specifies the last access event generated at an access controlled point upon use of this credential. If the credential this object represents has never been used, then this property shall have a value of NONE.
Property lastAccessEvent of object accessCredential can be read and written using a single IOTag.
accessCredential-<objectAddress>.lastAccessEvent |
<type> = 32 |
<property> = 275 |
An integer representing one of the options of enumeration <BACnetAccessEvent>.
