accessCredential.extendedTimeEnable |
Specifies which command of type BACnetDoorValue shall be used to command the access door when access is granted. If extended time is enabled (TRUE), EXTENDED_PULSE_UNLOCK is used, otherwise (FALSE) PULSE_UNLOCK is used.
Property extendedTimeEnable of object accessCredential can be read and written using a single IOTag.
accessCredential-<objectAddress>.extendedTimeEnable |
<type> = 32 |
<property> = 271 |
