accessCredential.credentialStatus |
Specifies whether the credential is active or inactive. Only the value ACTIVE enables the credential to be used for authentication. While the list in property Reason_For_Disable is nonempty, the status of the credential shall be INACTIVE, otherwise it shall be ACTIVE.
Property credentialStatus of object accessCredential can be read and written using a single IOTag.
accessCredential-<objectAddress>.credentialStatus |
<type> = 32 |
<property> = 264 |
An integer representing one of the options of enumeration <BACnetBinaryPV>.
