Examples of Tag Configuration |
To read or write the presentValue property of object "analogValue-300", on a device with address 15, declare a Tag with the following parameters:
•N1: 15 (device with address 15)
•N2: 2 (analogValue-type object)
•N3: 300 (object address)
•N4: 85 (the presentValue property)
For the same configuration by Strings, declare a Tag with the following properties:
•ParamDevice: "15:"
•ParamItem: "analogValue-300"
Or else:
•ParamDevice: "" (an empty String)
•ParamItem: "15:analogValue-300"
NOTE |
Configuration by Strings assumes the presentValue property if not informed. The value "analogValue-300" is equivalent to "analogValue-300.presentValue". |
To read a vendor's name, that is, the vendorName property from a device with number 15, declare a Tag with the following parameters:
•N2: 8 (device-type object)
•N3: 15 (address of object "device-15")
•N4: 121 (the vendorName property)
•ParamDevice: "15:"
•ParamItem: "device-15.vendorName"
Or else:
•ParamItem: "15:device-15.vendorName"
