ChangeWritePriority |
Allows changing the default value of the writing priority of a device. If the Device field is addressed, this Tag must inform only the new priority value, between 0 (zero) and 16. If the Device field is not addressed, this Tag must be an array in which the first field is the device's address and the second field is the priority.
