Driver Configuration |
This Driver's [P] parameters are not used and must be left with the value 0 (zero). Specific settings of this Driver must be configured using the BACnet tab on the configuration window, available on Driver settings in Elipse E3 or Elipse Power. In Elipse SCADA, select the Driver and click Extra in Organizer.
The Setup, Serial, Ethernet, Modem, and RAS tabs contain the configuration of IOKit library. For more information, please check topic Documentation of I/O Interfaces.
