DeleteDrugEntry |
A PLC Tag that receives an integer value to command the erasing of one item stored in this Driver's internal memory. This number value must match the position stored in memory. The first item included by the IncludeDrugEntry command is 0 (zero), the second one is 1 (one), and so on. When deleting an item from the internal list, the position of all other items changes, therefore the value to use on a new deletion must be reviewed according to the current situation of the stored list.
