Tag Reference
Tag Reference
This section contains information about the configuration of this Driver's Tags. N or B parameters are not used. Only the Item parameter is used to refer which Tag is executed.
Any word not expected as a Tag name in the Item parameter results in a fill error. N or B parameters filled with values different from 0 (zero) also result in a fill error.
