Configuring Properties
All settings are executed on this Driver's configuration dialog box. On this dialog box, the most relevant parameters are described on the next table.
Configuration options of B. Braun AutoProgramming Driver
Tab
Parameter
Offline String
Data Type
Description
Setup
Physical Layer
IO.Type
Text
By default, use the Ethernet option
Timeout
IO.TimeoutMs
Number
Time limit, in milliseconds, to receive data on a device's answer. For example, a value of 1000 defines a time-out of 1 (one) second
Logging options / Log to File
IO.Log.Enable
Number
Enable log generation and a log file name to generate for debugging purposes on communication. A value of 0 (zero) disables log generation and any value different from 0 (zero) enables it
IO.Log.Filename
Text
Ethernet
Transport
IO.Ethernet.Transport
Text
By default, use the TCP option
Main IP
IO.Ethernet.MainIP
Text
Device's IP address, in the format [0-255].[0-255].[0-255].[0-255]
Port
IO.Ethernet.MainPort
Number
By default, use the value 4002
In addition to this Properties Window, these settings can also be defined at run time in Elipse E3, Elipse Power or Elipse Water applications. For this, initialize this Driver in Offline mode, that is, execute an application with the Start driver OFFLINE option enabled, configurable on the Setup tab of the Properties Window, described previously.
All offline properties must be configured via PLC Tags in String format using the N1 parameter equal to -1 (minus one), N2 equals 0 (zero), N3 equals 0 (zero), and N4 equals 3 (three). For more details and examples, please check topic Documentation of I/O Interfaces.
