Driver Revision History
Version
Date
Author
Comments
3.0.2
09/01/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 37940).
3.0.1
03/16/2020
C. Mello
•Driver ported to IOKit library version 2.0 (Case 27446).
2.6.1
05/30/2011
A. Quites
•Fixed a vulnerability, which now rejects invalid frames but with a correct check byte, indicating an expected number of data bytes but with less bytes (Case 12264).
2.5.1
08/02/2010
A. Quites
•Fixed the way of declaring Struct data types in documentation (Case 10774).
•Data area separated to optimize and allow implementing threads to easily collect data (Case 10626).
•Fixed an error generated by the compilation of table files from applications in versions 2.2 and 2.3, when updated to version 2.4 (Case 10690).
•Added a thread to allow downloading event tables in background (Case 10625).
2.4.1
06/08/2009
A. Quites
•Driver changed to allow downloading multiple event tables (Case 10450).
2.3.1
10/09/2008
A. Quites
•Fixed an error when writing Date and Time data types (Case 9847).
•Implemented a detection of delayed responses (Case 9843).
2.2.1
07/25/2008
A. Quites
•Implemented a Struct data type (Case 9257).
•Implemented Timestamp and Mass Memory Reading features (Case 8266).
•Implemented support for String data types (Case 8766).
•Fixed an error in the date and time in UTC format in data type 14 (Case 9070).
•Fixed a problem preventing the use of IOKit library's Physical Layer Status Tag, which was not recognized by this Driver after the implementation of Superblocks (Case 8816).
2.1.1
01/17/2007
A. Quites
•Added support for Superblocks (Case 7663).
2.0.1
08/11/2006
A. Quites
C. Mello
•Driver ported to IOKit library (Case 3882).
•Implemented 32-bit and floating point data types (Case 3943).
•Implemented a Date and Time data type and signed 16-bit and 32-bit data types (Case 6457).
1.0.1
R. Haetinger
•All releases previous to revision control, without the IOKit library.
