ST-63: Load Profile Status
Read-Only
B1
0 (zero)
B2
63
B3
Not used, leave it in 0 (zero)
B4
Size
6 (six)
•Element 1: Status flags of a Load Profile set (bit fields)
•Element 2: Number of valid data blocks of a Load Profile in their respective tables
•Element 3: Index of the most recent element of the data block array on a Load Profile data array
•Element 4: Sequence number of the most recent valid data block on a Load Profile data array
•Element 5: Number of blocks not yet read
•Element 6: Number of valid intervals generated on the most recent block of a Load Profile
