ST-60: Load Profile Dimension Limits
Read-Only
B1
0 (zero)
B2
60
B3
Not used, leave it in 0 (zero)
B4
Size
7 (seven)
This table specifies the maximum dimensional values, the control selectors, and data options of a Load Profile.
•Element 1: Memory size of a Load Profile
•Element 2: Flags of a Load Profile
•Element 3: Flags of acceptable formats of a Load Profile
•Element 4: Maximum number of blocks that can be contained in set 1 (one) of a Load Profile (table 64)
•Element 5: Maximum number of intervals per block that can be contained in set 1 (one) of a Load Profile's data (table 64)
•Element 6: Maximum number of channels in set 1 (one) of a Load Profile's data (table 64)
•Element 7: Maximum time, in minutes, for the duration of an interval that can be contained in set 1 (one) of a Load Profile's data (table 64)
