ST-00: General Configuration
Read-Only
B1
0 (zero)
B2
0 (zero)
B3
Not used, leave it in 0 (zero)
B4
Size
22
•Element 1: Format control 1 (one, bit field)
•Element 2: Format control 2 (two, bit field)
•Element 3: Format control 3 (three, bit field)
•Element 4: Device class (String)
•Element 5: Nameplate type. Possible values are 0: Gas, 1: Water, or 2: Electrical
•Element 6: Default configuration. Possible values are 0: Not used, 1: Simple meter register, 2: Simple demand meter, 3: Simple TOU meter, or 4: Simple profile recorder
•Element 7: Maximum length of procedure parameters
•Element 8: Maximum length returned by procedures
•Element 9: Version of standard tables
•Element 10: Revision number of standard tables
•Element 11: Number of octets required to represent standard tables
•Element 12: Number of octets required to represent manufacturer's tables
•Element 13: Number of octets required to represent standard procedures
•Element 14: Number of octets required to represent manufacturer's procedures
•Element 15: Number of octets allocated for specific manufacturer's status indicators
•Element 16: Number of sets of pending statuses on the table of pending statuses (table 4)
•Element 17: String as hexadecimal characters indicating which standard tables are implemented by a device
•Element 18: String as hexadecimal characters indicating which manufacturer's tables are implemented by a device
•Element 19: String as hexadecimal characters indicating which standard procedures are implemented by a device
•Element 20: String as hexadecimal characters indicating which manufacturer's procedures are implemented by a device
•Element 21: String as hexadecimal characters indicating which standard tables are writable
•Element 22: String in hexadecimal characters indicating which manufacturer's tables are writable
