LastComtradeTime
LastComtradeTime
Reading or Writing
N1
Modbus address of a device
N2
1 (one)
N3
0 (zero)
N4
0 (zero)
ParamDevice
Address of a device
ParamItem
AlstomP12x.LastComtradeTime
Use this Tag for writing in cases when users must configure a timestamp value, which this Driver uses to update files. This Driver only requests records from a device with dates after that value. The initial value of this Tag is 01/01/1994 00:00:00.000.
After generating files in COMTRADE format, this Tag uses this value for the time of the newest file already saved. The data type of the Value property is TIME.
