Tag Reference
Tag Reference
This section contains information about the configuration of Tags of this Driver. These Tags can be configured either by using Strings in the ParamDevice and ParamItem properties in Elipse Software applications or by using [N] parameters.
Symbolic Address Fields
•The ParamDevice property contains the Modbus address of a device
•The ParamItem property refers to the name of a Tag, according to its function. The available Tags are the following:
•AlstomP12x.ComtradeFileBaseName
•AlstomP12x.ComtradeFileName
•AlstomP12x.LastComtradeTime
•AlstomP12x.Status
Addressing Fields by [N] Parameters
•N1: Modbus address of a device
•N2: Command
•N3: Not used, keep it as 0 (zero)
•N4: Not used, keep it as 0 (zero)
