Pagination Tag
Pagination Tag
Write-Only
Use a PLC Tag to define the pagination values of the values returned in the Ada system.
Syntactic parameters
Device
Not used and must not be filled
Item
Pagination
N parameters
N1
Number of items per page
N2
0 (not used)
N3
0 (not used)
N4
0 (not used)
The Value field must be populated with the page number, and the N1 parameter defines the number of items each page must contain.
