Devices/Readings.Values Tag
Read-Only
Use a Block Tag with 8 (eigth) Elements to read the values from the list of values contained in the Ada system. Use this Block Tag for as many devices as needed to perform a reading.
Syntactic parameters
Device
Keyword to bind with the Devices/Readings.Download Tag
Item
Devices/Readings
Elements of this Block Tag
corp
serial
type
timestamp2
pressure
acc_flow
instant_flow
reading_index
