Devices/Readings/Latest Tag |
Use a Block Tag with 8 (eight) Elements to read the last values from the list of devices contained in an Ada system. Use this Block Tag for as many devices as needed to perform a reading.
Syntactic parameters
Device |
Fill with the serial value of a device to read |
Item |
Devices/Readings/Latest.Values |
•corp
•serial
•type
•timestamp2
•pressure
•acc_flow
•instant_flow
•reading_index
