Devices/Readings.Download Tag
Write-Only
Use a Block Tag with 3 (three) Elements to execute a download command of historical reading values from the referred device.
Syntactic parameters
Device
Keyword to bind with the Devices/Readings.Values Tag
Item
Devices/Devices.Download
This Block Tag must be written as a whole block. The first Element must contain the serial values of the devices to read. In case of more than one device, separate each serial value by a comma. The second Element must contain the starting date and time, and the third Element must contain the final date and time of the collecting.
Serial
InitialDateTime
FinalDateTime
