Preparing a Device
Preparing a Device
A device must be configured to start connecting to this Driver, and users must configure the next parameters:
•Host Address/Port: IP address and TCP/IP port that a device uses to connect. The IP address must be the one from the computer of this Driver, and the TCP/IP port must be the same one configured in this Driver in the Listen Port option on the Ethernet tab
•Host Type: Must be equal to 2 (two)
•Host Login: Code with 8 (eight) characters send as soon as a device connects to the IP address and TCP/IP port informed. This very code must be informed in the ABS.ini file. For more information, please check topic Driver Configuration
NOTE
Some products support several connections with a different identifier for each one of these connections, and in this case please contact ABS's technical support.
